9.60c error: SetupDiEnumDeviceInterfaces in SETUPAPI.DLL
Upgrade from 9.47d to 9.60c. On startup get the following error from WeatherD.exe
The procedure entry point SetupDiEnumDeviceInterfaces could not be located in dynamic link library SETUPAPI.dll
Running on NT4 server SP 6a, version 4.00 of SETUPAPI.dll
Can’t readily locate information on any later version of SETUPAPI.dll or cause of failed call to dll.
Any advice please?
Reverted to 9.47d OK
i think it was adding the labjack support,which is not NT compatible, but i have that separate now
try vers 9.61
I tried 9.61 but unfortunately I still get the same error message.
rgds
John
ok, you have to use the win95/nt version
http://www.weather-display.com/download/wdisplaywin95.exe
(which i will update the latest version soon)
the only difference with that version is no direct web cam support
the lab jack requires USB you see
