does any other software work with it (for the 8 channel relay)
Know other software , only wd
I am using my old laptop , with the relay board with the USB adapter
Which should work for my automatic damper project
Plus 2 temperature sensors
Will test tmorow with the temperature sensors to switch relay on and off
Thanks for adding this to wd
Update
Have the relay board working with extra temperature sensors
Dear Brian,
could you please add 8-channel relay switch statuses (ON/OFF) into the tagslist.txt? It would be useful to use them for monitoring purposes - e.g. in the custom screen setup etc.
Many thanks!
Best regards
Pavel
