64 bit Weather Report Email
Good Evening
I have just updated my Weather Display software to version 10.37S build 151, everything works fine apart from the weather report email which now seems to be formatted in 64bit code (I am currently using Win 10 Pro 10.0.19045 Build 19045), the report within the email is now corrupt. To check, I have reverted back to my previous working version of Weather Display 10.37S Build 149 and the weather report email is formatted correctly (the email is coded as 7bit). Is there a setting within Weather Display that needs to be configured that controls the bit number (7 or 64bit) for the weather report email? Any help greatly received.
Many thanks
Steve
Might have to ask Brian direct, at [email protected]
I am seeing a related issue with the same Windows version of WD in that my weather report emails are displaying the raw html even though the ‘Use html format’ option is still ticked. Worked in the previous version (10.37Sb150).
I am reverting to the previous version of WD until a S/W update is available that addresses this issue.
Have you notified Brian about this? I’ve only seen you mention this so it might not be a common problem that he’s aware of…and therefore might not be looking for a fix for it.
Hi, I did send an email outlining the issue to the email address above. To date I haven’t heard anything back, following reverting to the previous version everything had worked correctly.
Brian had been on an extended holiday and I’m not even sure if he’s home yet so that’s probably why you’ve not heard anything.
Might explain why I’ve been waiting for advice on a different matter. . .
Glad to see it isn’t just me who is seeing this. Thanks.
I too am having issues with the weather report email, I’ve tried three different mail servers, smtp, even pop3, nothing wants to work, errors like
276: error during handshake[2]: 0x80090308,
161: SMTP protocol error. 535 5.7.139 Authentication unsuccessful, basic authentication is disabled. [YT4PR01CA0500.CANPRD01.PROD.OUTLOOK.COM 2025-01-09T18:11:57.691Z 08DD308ABC9434A9].
The above error comes up often, with all the mail servers, I have completely exhausted all possible setup requirements as far as the different switches like "Use explicit SSL start mode, etc etc, but to no avail. Is there something I’m missing ?
Thanks for any input…
Nick. dw7240.com
