3 in 1 Skript Problem
Hello everybody,
I tried to get the 3 in 1 script to work. Still, it didn’t quite work out. The data from Wxsim appears to be displayed. However, nothing is displayed when you click on the buttons, the graphics do not work, as well as the translation. I’m also not sure which path has to go in line 27 of the settings. # $ cachedir = “/ home / web3 / fmi / cache /”; # Cache location for downloaded forecasts. Maybe it’s because of that too. Has anyone had an idea or the same problem?
https://büchelbergwetter.de/WxsimSkripts/Skript2/wxsim_wxall/sivu2.php
The cache setting looks correct, as long as there are no gaps in the text. It should look like this:
$cachedir = "/home/web3/fmi/cache/"; # Cache location for downloaded forecasts
Have you checked your settings in WRET and made sure the latestwret.txt file is being uploaded, as this can sometimes cause issues?
I’ve attached the image of the recommended settings for WRET below.
The attitudes in Wret should be correct. I couldn’t find a file with the name latestwret.txt or wret.txt in my wxsim folder?
I only found wretopen.txt and wretlog.txt. But all files are automatically uploaded with an ftp.uploader.
Sorry, I got the wrong spelling. :oops: #-o
It should have been “lastret.txt” and the location of that file goes into the line 9 in the settings file.
lastret.txt is uploaded correctly and the path should also be correct. The ewn-style script is running. I suspect that it may be due to the time stamp, as it is not at: 00 for me through meteohub. But I can’t find a line about it.
