10.20M missing parts of GUI when using netmeeting?
What is up with WD 10.20M.
typical that the new transparency thing has put a spoke in the wheels somewhere…
the problem is it works without doing any thing…
so if others have trouble too, then i will remove it
(and instead use a different method (which is in use for the floating window (check it out, in 10.20n)
(the different method will be safe, and will work on all windows versions…but no fade affect (this new transparency fade affect only works on windows 2000
although no other problems reported, its gone in 10.20o
Gosh don’t remove it just for me. I must be the only user that’s WE server doesn’t have a monitor. I run Win2k and use netmeeting to manage the server. If there were simply a way to turn it off for certain users that would work wouldn’t it.
i could not turn it off, it was a all or nothing
but i do have it working still, in a fashion, see under the misc setup
Not sure if netmeeting is a requirement for you but you could always try VNC or MS remote desktop. I know VNC works fine for me to view WD on my another PC.
