10.18i Sticks with input from Datalogger
Goes and gets up to date info, reaches 100% then sticks there. Won’t continue
Went back to 10.18g and it doesn’t get stuck there.
it wont be a version thing you will find
(as nothing changed in the program, and it does do that from time to time)
it should time out, on its own, or you can just click on abort
Brian, I am having the same issue. I have attempted to download the data logger several times it will hang before it updates the log files and graphs.
Chuck
humm
i will do a test here…
but, does clicking on abort let it carry on?
For me… it cleared the box… but the console never updated to current information. I left it that way for bout 15 min’s when I got a phone call during one cycle.
I stopped and restarted the program several times.
Eventually, I reloaded 10.18g and it worked properly right off the bat when I restarted.
I saw you note about there not being any difference, but I’ve not yet attempted to try it again. Been working on the wap page and some other things since I have the time to tinker with those.
her the same!
After ten times i startet WD it works without to load the data from the logger.
When you click on abort the programm is hanging and not continue!
Cheers Stefan
dang
you are right
but i have it fixed now
(it was small change I had made, which made a piece of code get missed altogether)
the weather-display server is down at the moment
so uploading a fix to another one now
oh, goode
the wd web server is back again
i will let you know when its ready to download, the fix
if you are quick:
http://www.weather-display.com/uploads/WeatherD.zip
otherwise from the normal location if that file cant be found :slight_smile:
sorry about this stuff up :oops:
Same problem with 1018i here, but 1018j fixed it.
Cheers
:smiley:
MikeyM
