No logging is taking place in the chronlazersnow app window
This may be an issue of me sending the incorrect device info…but thanks so much for your patience and trying
you have sent the correct info
does it say connected?
it might be that I need to send a command to get it to log
it might be that you need to run the software that comes with it at the same time
(try doing that with the dallas1wirereader program)
Bad news…
The LR Demo Program runs but there’s no data being measured…even after a complete system restart & unplug/plug USB
Cron Lazer Snow shows nothing…
UPDATE:
I got my usual setup going again…give me a few minutes to try the cron program again
Cronlazersnow still is not logging or sending any message regarding connecting…by the way in the US laser is with an “s” not “z”
Thanks for your efforts
Would downloading the free LRSimple program from porcupinelabs.com …that I can verify is logging… help you?
try running dallas1wirereader with the software that comes with the station running at the same time (start that first)
Sorry…
No data flowing to 1-wirereader or new cronlazersnow as data is being logged by the LR4sample programs
the best thing is I need the hardware here
try another cronlazer snow download (same url)…and see if it at least connects to the hid device now
I tried the latest and it shows lazer snow connected twice. The left panel shows the word data numerous times. I’m guessing that is what you want to see. I just used lrdemo.exe and cronlazersnow.exe not the 1-wire. Off to bed we’ll see where you are in the morning.
Rick
good news…if it says data…then its working (I have not processed the data yet, just acknowledged that data is arriving)
another update ready…same url…see if it shows data now
After I start the laser measure, then unzip your cron app, then it shows the following…screen shot
However, if I quit and try again…no luck
try another update
will say vers 1.1 now across the top
it should show the data now
also laser1wire reader – no luck with new cron showing any data
Hold on wrong file
It also started snowing…have about 5mm
good
the raw data is coming in
it looks like the first value (the D value) is the depth?
a user of the working dallas1wire reader will need help in reminder me how this all works again , as I had lost the original code
