I tried to update my weather computer with the new weatherdisplay.exe, LRTimelog.exe, cronlazersnow.exe, AtUsbHid.dll and cronlazersnow will not see the lazer. Then I copied the entire subdirectory from the test computer I was using the past few day to the weather computer to a subdirectory totally independent of my original WD subdirectory and it works perfectly. It appears that there is a file missing somewhere and I can’t figure out where. I’ll go back over all the files you sent during the last week and see if I can find the missing link.
Yes, shutdown WD and cronlazersnow and restarted. Also, not that it may not be relative, but when my page is refreshed the snow information is correct but after the 3 second ajax update the snow data is not correct. See here http://indiantrailweather.com/index.php . Snow today should be “0” and snow depth should be “.2”
not sure about your web page, expect that it sounds like it goes wrong when it gets the data update from your clientraw.txt file?
I did make any changes to the format in the clientraw.txt file
question
using windows device manager, what is the VID and PID of your lazer sensor?
does the LRtimelog.exe program find it?
I’m not sure how to find the VID and PID of the lazer sensor using Device Manager. The original (Porcupine) LRtimelog.exe and LRDemo program do find and connect to the lazer sensor
I'm not sure how to find the VID and PID of the lazer sensor using Device Manager.
its easy
just run windows device manager
then under ports, you should be able to find ports, then there should be a list of USB/HID devices
and then find the lazer one, and see what info in regards to PID and VID show under properties
running that here shows my mouse in the list
if you have a usb.dll file or a hid.dll file
where WD is installed, then try deleting those
(also try running that test program from another folder location)
