1 hour weather forecast in sky block
Oké, almost everything is working now on my site :slight_smile: great thanks to everybody here.
But 1 thing is left, the weather forecast is not updating… and can’t figure it out why not.
so where are you trying to get the forecast from?, (pirate weather, Xashila, Metar??)
I’m using Openweathermap with a new api key but still nothing, worser, i’m offline now .
WAIT!! got it wrong it is not the weather forecast but the sky conditions :slight_smile: i’m the default current weather now from our metar with key
something is still wrong as there is no update in the sky conditions.
are you using the correct key?
I tried Aeris Weather, upload to pwsweather goes wel but when i select aeris i’m getting a error.
https://www.pwsweather.com/local/nl/medemblik
Have you signed up to Aeris weather? and got the api key etc and put those details in PWS dashboard under the settings tab
yes i have… but now i’m not sure if i did the right thing… what @ api access ID ? I got: WSMEDEMBLIK and the secret key
after saving this error
I think WSMEDEMBLIK is just the name of your station at PWSweather. . .
When you sign up to “Aeris” you should get an API access ID and a secret key.
My PWSdashboard and Saratoga template use the same 21-character API access ID but have different 40-character secret keys.
hmm, i only see one secret api key at my profile … where to find the ID key ?
access ID is called Client ID
Oké, and where to find my client ID ? i only see the secret app key .
But i think i leave as it is now… it is not important this part of the website.
PWS_weather
If you want to upload to pwsweather you have to get a pwsweather station-ID and a key to upload to PWS_weather.
Aeris forecast and other goodies
When your station is uploading correct data for a few days, you can ask the parent company xweather.com (formerly Aeris Weather) to use their free access plan
Step 1: read https://www.pwsweather.com/contributor-plan and click the green button
Step 2: Use your e-mail address and password for pws-weather to signup PWS Contributor Signup - Xweather
Step 3: You will get at a page where you can get an ID (a string of characters) and an API-key = another string of characters.
For accessing the aeris (= xweather) data you do not use the credentials for pwsweather. You use those you got from xweather.
great job !! it works :slight_smile: thnx al lot
